06-05-2020
05:51
13:33
JuanFitbit
06-05-2020
05:51
13:33
JuanFitbit
Brand new versa 2 -works fine -heart rate data consistent 24/24. Premium trial member -
App is only showing basic sleep data. This is s large part of reason I bought this device and subscribed to premium.
@Fitbit please help.
06-06-2020 02:31
06-06-2020 02:31
Bump. Med too.
Best Answer06-28-2023 06:40
06-28-2023 06:40
Me too, have you found a solution?
Best Answer06-28-2023 13:33
06-28-2023 13:33
@EllaandLaura @JeffMindlin @Tranebird Nice to see you all around. Thank you for your messages.
The following conditions can prevent the recording of sleep stages:
- You record your sleep using the app instead of the tracker's automatic sleep detection.
- The tracker's battery is almost empty when you go to bed (below 25%). This prevents a regular recording of the heart rate.
- You use the metal bracelet while sleeping
- You sleep less than 3 hours.
- The bracelet is too loose or too tight on the wrist. You should be able to put your index finger between the bracelet and your arm without much resistance, so that your heart rate is recorded regularly and the sleep phases can be recognized.
If you tap the recording that doesn't show you sleep stages, you should get a message explaining why you didn't get any. What does it say?
Best Answer06-28-2023 16:08
06-28-2023 16:08
My last post was 3 years ago.
move moved on from Fitbit and have a much better fruit themed watch now which is more accurate, reliable and far superior.
