Versa 2 + Inspire
ANSWERED
Hi everyone,
I have a Versa 2, but in my job I have to be bare below the elbows and still want to get my steps and distance counted. I have just bought an Inspire with the intention of wearing it on my ankle/clip case.
However, I can't seem to add it to my account without have to reset/sync the device each time I swap.  I had hoped I could wear inspire 9-5 and still use my versa 2 evenings and weekends.
Any help would be greatly appreciated!
1 BEST ANSWER
Accepted Solutions
Sorry, but that is not possible.
Quoting from Can I use more than one Fitbit device with the same account?
Note that you can't connect multiple devices that use the Fitbit App Gallery to one account. For Fitbit Charge 3, Fitbit Charge 4, Fitbit Ionic, Fitbit Inspire series, and Fitbit Versa series, only connect one of these devices to your account at a time.
If you can return the Inspire, you might try putting the V2 in a pocket usually gives decent step count, or some take the band off and put the pebble in bra, though getting the V2 band on and off can be troublesome.
2 REPLIES 2
I had the same question as the original poster. Fingers crossed the pocket trick works! Been 6 months since I haven’t been able to wear it. 😭
