01-20-2020 02:21
01-20-2020 02:21
I have been using Fitbit Versa 2 for 4 months.
On January 11 the pulse function stop working.
If I reboot my Versa 2 it works for some time. (Not allways)
I have tried to set Pulse Off, reboot, Pulse On and reboot, nothing helps.
What to do ?
01-20-2020 07:43
01-20-2020 07:43
Have you tried shutting the Versa 2 off, then restart?
Are the green lights flashing.
Best Answer01-20-2020 08:18
01-20-2020 08:18
Best Answer01-20-2020 08:30
01-20-2020 08:30
My Versa does that all the time. 😞
Best Answer01-21-2020 05:43
01-21-2020 05:43
Best Answer11-07-2021 01:42
11-07-2021 01:42
Hi,
I have the same problem. Tried factory Reset and even shut it down a couple
of times but nothing works. Any idea what to do next?
