09-22-2019 14:47
09-22-2019 14:47
In Versa 1 in Settings you can disable notification when you are asleep and Versa 1 automatically determines when you are sleeping and disables all notifications.
In Versa 2 you need to setup your sleeping hours, there is no option to disable it automatically. But if you, for example, have two shift job, you cant setup sleeping hours, because they are different depending on the day. There is Only one way to activate sleep mode - manually, but it very easy to forget to switch it back. Also when I activate on my phone(iphone X, ios13) a sleep mode - I still receive notifications on my watch.
I don’t understand why fitbit removed previous options. Now I feel completely uncomfortable to enable/disable sleep mode every time when I go to sleep, even if I want to nap 1hour.
09-22-2019 15:00
09-22-2019 15:00
@Mrscotland wrote:In Versa 1 in Settings you can disable notification when you are asleep and Versa 1 automatically determines when you are sleeping and disables all notifications.
Are you sure? I'm not aware of Versa 1 time asleep having any interaction with any other function. Can you tell how you set that, or reference any instructions or documentation on it?
Best Answer09-22-2019 16:12
09-22-2019 16:12
Versa 1:
Settings -> Notification -> During Sleep(on/off). Once you setup “off” you will not get any notification when you asleep.
in Versa 2 there is no such option anymore.
Looks like fitbit decide to downgrade smart part of their new device.
12-26-2019 17:05
12-26-2019 17:05
I am so disappointed in Fitbit with the Versa 2.. thought it was an upgrade but honestly felt like a downgrade! Don;t even talk about the charger.. but seriously it sucks that they now want us to manually set our watch to sleep mode. This option has been there since Charge HR (what I had) and now in the latest model, it's completely gone. This made me think, it Versa 2 can't even know when we are sleeping, does that mean the sleep insight will be completely off and unreliable?? I will talk to support and see what they say, might go back to Versa 1 if they can't assist as I don;t have a usual sleep time and not comfortable to manually start sleep mode. Sometime I am so tired that I just need to sleep.
12-26-2019 23:51
12-26-2019 23:51
Fitbit 1 was downgraded to fitbit2 😀 Google please dismiss department who created this watches. You got x2 bucks after purchase fitbit and now you can find smarter developers😀
Best Answer12-27-2019 00:01
12-27-2019 00:01
I contacted support earlier, they confirmed that the Versa 2 should automatically detect sleep and turn off notification. They asked me to reboot the watch by pressing and holding the button for about 10secs and also referred to this link: https://help.fitbit.com/articles/en_US/Help_article/1314/?q=sleep&l=en_US&fs=Search&pn=1#howdoesmy
I will try again tonight and get back to them if it still doesn't work.
Best Answer12-27-2019 07:32 - edited 12-27-2019 07:32
So support got back to me:
--"We're sorry but our higher level of support confirmed that the Versa 2 does not automatically disable notifications even though it detects that you are already sleeping. We sincerely apologize for the confusion.
Moreover, we confirmed that the "Do not disturb" and "Sleep mode" features on the Versa 2 are the counter part of the "During sleep" option of Versa. With that, turning on these features is the best we can recommend in order to avoid receiving notifications on your watch while sleeping.
We're constantly striving to improve Fitbit products and services, and we very much appreciate all of the input we receive from our customers. The more votes the post regarding this in the community gets, the more chances it will have to be reviewed by our product specialist and may be consider in our future product improvements."--
I replied to them with a very long and not too happy email. Just don't understand what was going on with the dev team to remove this option.
Anyway, I have also started a new feature suggest, although this is more like "put back what you have stolen from us" request. You can vote if you would like to see Fitbit do something about this.
01-06-2020 17:36
01-06-2020 17:36
I turned on sleep mode under my settings on my watch and now it won't let me back into that to turn it on. Not happy with this one at all!!!!
01-07-2020 06:54
01-07-2020 06:54
I turned on sleep mode via quick settings. Changed my quick settings...can not get out of sleep mode.
Best Answer01-09-2020 05:55
01-09-2020 05:55
For some reason my suggestion was marked as spam and can't see link I posted here.
Here is the link to the suggestions btw: https://community.fitbit.com/t5/Feature-Suggestions/Bring-back-During-Sleep-notification-setting-on-...
Weird!!!! Fitbit??
Best Answer01-09-2020 07:05
01-09-2020 07:05
Best Answer12-21-2021 12:14
12-21-2021 12:14
My daughter's versa 2 will track even if she takes a short nap, they tell me go into the settings and change sleep sensitivity, and I don't have that option either, and that was from fitbit, I'm lost lol
