04-05-2020 19:08
04-05-2020 19:08
Hello,
My Versa 2's screen is not swiping and is frozen on the main home screen. I have restarted over a dozen times and it did not fox the issue.
I would be happy to try a factor reset but I think you can only do it from the settings app on the watch, which does not help me because I cannot get to the settings screen.
Does anyone know a trick to do a factory reset without needing to go through the screens?
Or, does anyone have a different fix for my frozen screen?
Thank you in advance!
04-06-2020 20:50
04-06-2020 20:50
@SherBear87 You can attempt hard reset using button:
You can set up the watch back to the Fitbit account by following the instructions on this link: How do I set up my Fitbit device?
If you're not successful with the factory reset, I am afraid you will need to reach out to Customer Support to guide you through the next steps. Here's the link to Customer Support page.
Best Answer04-06-2020 20:50
04-06-2020 20:50
Best Answer04-07-2020 17:26
04-07-2020 17:26
I just did this and was able to do a factory reset.
The screen is still not swiping though and is now frozen on the quick tips start page.
I will go through the customer support page you linked.
Thank you for all your help !
Best Answer04-07-2020 17:49
04-07-2020 17:49
@SherBear87 the good news is you should still be under warranty and as far as I know Fitbit are pretty good about their replacement policy. Good luck! 😄
Best Answer11-20-2020 03:11
11-20-2020 03:11
Did you find an answer to the problem? Mine is doing the same thing.
