08-03-2023
13:26
07:50
08-03-2023
13:26
07:50
Versa 2 has been acting completely out of the ordinary and I see others having these same issues. My battery dies with no warning and much faster than normal. The screen doesn’t display the % charged now. When I take it off the charger the Fitbit logo stays on the screen until I reboot.
Hi there, @JJsJuke. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
As a first approach, I'd recommend trying the tips and recommendations provided here Why ins't my Fitbit device's battery charging?
If you continue seeing the Fitbit logo after the steps above, while your Versa 2 is in the charger, please try these steps:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
05:58
06:20
EstuardoFitbit
08-07-2023
05:58
06:20
EstuardoFitbit
This did not correct the issue. I assume the software was upgraded and that is the cause?
This didn’t work. Now what?
Now battery is draining after 1 1/2 days. Still doesn’t show percent charged and have to restart every time it charges.
so frustrating
What else can you offer? The canned reply you give everyone didn’t help at all
