04-15-2024
09:35
06:22
04-15-2024
09:35
06:22
Why has Fitbit become so unreliable? Won’t sync, won’t connect to phone, battery goes flat really quickly then is ok for a while? Fitbit used to be solidly reliable, it’s so bad now I’m not sure there is any point in wearing one now.
04-16-2024 06:25
04-16-2024 06:25
Hi there, @AlanDixie. Welcome to the Fitbit Community Forums. I'm sorry to hear about the issues you've been experiencing with your Versa 2. We‘re taking your comments and sentiments in regards to our products into consideration. I will do my best to help you with this!
Regarding the battery draining fast, please keep in mind that your Versa 2 battery should last up to 6 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
As for the syncing issues, please confirm whether you've tried all the tips and recommendations provided here Why won't my Fitbit device sync?
