Versa 2 battery draining quickly
I got a new Versa 2 in May. Fully charged it Sunday and it went down to 10% but Monday. Same again has happened today. Anyone know if the battery is faulty or any ideas how to fix it?
Moderator Edit: Clarified subject and label
1 REPLY 1
Welcome! It's great to see you around @HornerBFC
Thanks for sharing the details about the issue with the battery on your Fitbit Versa 2.
Please note that the battery on this Versa 2 can last up to 6 days; because battery life is affected by use and other settings, actual results may vary. Before considering other options, please make sure that you've reviewed the tips provided in this article.
By the way, I've moved your post to the Other Versa Smartwatches board for organization purposes.
Hope this helps.
Cindy|Community Moderator| Did you find my post helpful? Vote for it or mark it as a Solution!
