02-08-2021
09:26
04:12
02-08-2021
09:26
04:12
I have a Fitbit versa 2. I have it just over 2 years, and the battery life is rapidly slowing down. I'm just wondering did anyone else experience this? Did you buy a new watch?
Hi there @JimJam19945, welcome to the Community Forums.
As you may know, your Versa 2 battery should last up to 6 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Seems like this is a common issue. Possibly due to a recent update, if it was working before.
In which case its probably best to inform Fitbit Support directly. They may be able to help you.
