11-26-2020
07:57
13:07
11-26-2020
07:57
13:07
I charged my Versa 2 this morning as it was at about 20%. I gave it about 2 hours and that got it to 100%. I would normally expect the battery to last about 2-1/2 to 3 days from 100%, but it has drained to 8% in the space of about 6 hours. I have not changed any of the settings so have no idea what is happening. I have not had a software update in the past month, so am at a lose as to what is going on. Anyone else having this problem. I should add, the weather is cool, but not hot or cold. I have had a quite day, so no need for it to be on high GPS usage.
Confused!
Hi there @LizzleCat, it's nice to see you around the Community Forums. Thanks for the details shared in your post, I understand where your concern is coming from and how you must be feeling. I'll be glad to help you.
As you may know, your Versa 2 battery should last up to 6 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
