12-10-2020
12:29
08:53
EstuardoFitbit
12-10-2020
12:29
08:53
EstuardoFitbit
My Versa 2 will not hold a charge for more than a day. I charge it at night and it is dead by the evening. I used to be able to wear it for 3-4 days before I had to charge it again.
Hello @Martinabus, I understand why you're feeling disappointed. Thanks for your feedback as it helps us to keep improving.
As for the heart rate that is not working, please try the following:
For more troubleshooting steps, see: What factors can affect my heart-rate reading on my Fitbit device?
Keep me posted on the outcome.
Hi there @Martinabus, welcome to the Community Forums.
As you may know, your Versa 2 battery should last up to 6 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Let me know how it goes.
Best AnswerI am also having the same issue, has been the same since Monday, it is also not tracking steps. Really not very old, products are definitely not worth the money anymore!
Hello there @Saz001, welcome on board. We acknowledge the limitation we have on our part particularly on what you have experienced. We‘re taking into consideration your comments and sentiments with regards to our products and services.
If you're having issues with the battery of your Versa Lite, please take a look at my previous post for tips and recommendations to conserve your watch's battery life.
Regarding your steps that are not being tracked, I'd like to know if "steps" is the only stat missing? Are you seeing your calories, floors, distance, etc? In the meantime, please restart your watch by following these steps How do I restart my Fitbit device?
Let me know how it goes or if you need further help.
Hello @Martinabus, I'm glad to hear that the steps recommended solve the issue with your heart rate.
Regarding the battery life of your Versa 2, please check this post I made for you here.
Let me know if you need further help.
Best AnswerUpdate: my Fitbit is completely dead now. It won't turn on or charge at all. I have had it on the charger for several days and still nothing. Any ideas?
