01-20-2021
08:37
11:03
01-20-2021
08:37
11:03
My fitbit versa battery is not lasting long at all, it will last for 2 days
01-20-2021 10:44
01-20-2021 10:44
Is this new?
Have you checked your settings on the watch?
recommend
Brightness = auto
screen timeout = 10 seconds
Sleep mode - setup a schedule
Screen wake = auto
Vibrations= weak
And most importantly check the watch face your are now using is causing this if you just changed watch face.
01-20-2021 11:04 - edited 09-25-2024 13:12
Hi there @Selsouth1, welcome to the Community Forums.
As you may know, your Versa 2 battery should last up to 6 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display, etc. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Let me know how it goes.
01-20-2021 11:35
01-20-2021 11:35
My Versa just started having battery issues...last less than a day...checked all setting and did a factory reset.
Lost 25% in 2hrs.
01-20-2021 11:45 - edited 09-25-2024 13:12
Hi there @LeeStew, welcome on board.
Are you using Always-On feature? If so, please keep in mind that this may be causing the battery to drain quicker than expected. Also, please try switching to a clock face developed by Fitbit to see if the battery life improves.
Keep me posted.
01-20-2021 14:42
01-20-2021 14:42
I did the newest update a couple days ago, that I kept getting notifications to do so. Now my battery drains so quickly. I used to charge every 4 days, now I have to charge everyday! By 6pm it’s at 19% its ridiculous. The only thing that changed, was the new update.
01-20-2021 14:59 - edited 01-10-2024 11:33
@Jaclynlav Welcome here!
At this moment, the limits of what we can do for you here on the public community forums for the issue you're experiencing have been reached, so I've contacted our Support Team on your behalf to look into this issue further and provide you with some options. Please keep an eye on your email inbox for further instructions. Note that due to recent events affecting our operations, support options are limited and wait times are longer than usual.
