02-17-2021
13:18
05:35
02-17-2021
13:18
05:35
My versa2 battery is lasting less than 48 hrs. I've had the watch less than year. I have reset the watch to factory and it didn't help. The battery use to last almost a week.
Hi there @bonesaf27, welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa 2.
As you may know, your Versa 2 battery should last up to 6 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
