01-16-2022
23:18
09:58
01-16-2022
23:18
09:58
Hi Fitbit Team,
I have nothing on my Versa 2! Everything is black! Logged into the Fitbit app and it is indicating battery is full and Versa is updated. 3 days ago all normal - now nothing- just a black screen.
Can someone please help as I need this for work!
Thanks
01-18-2022 05:11 - edited 11-02-2023 03:34
Hi there, @PaulB47. Thanks for stopping by in the Community Forums.
Please restart your Fitbit device as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
01-17-2022 10:00 - edited 03-15-2024 16:18
Hi there, @Kinmarl. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2. I understand where your concern is coming from.
I've seen you contacted our Support Team after posting here and they've already assisted you with this matter. If you still need help, please feel free to contact our team back so they can continue assisting you.
01-18-2022
01:43
05:10
01-18-2022
01:43
05:10
hi…
I’ve got the same, what was the outcome, did you get sorted..?
Moderator Edit: Formatting
Hope that helps.
