Versa 2 button stopped working
Fitbit versa 2 button doesn't work and off hours displayed unable to change
4 REPLIES 4
Welcome to the Fitbit community, @Eleni22!
Sad to hear that your Versa 2 isn't working as it should. As over time dust and debris can collect in the small space around the button, I'd suggest soaking your device in a bowl with water for some time. Then give it a soft rinse and dry it with a towel. Finally try if the button is working again.
If it won't, please call Fitbit support to get further assistance:
Fitbit Support Contact
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Versa 4, Charge 6, Aria, Aria 2
Thank you for your email.
Just going swimming. Maybe it might get it working properly again.
Otherwise, I'll try your advice.
You're welcome, @Eleni22.
I'll keep my fingers crossed.
Stefan
Hello
It hasn't worked. Can I upgrade to a newer version?
Kind regards
Helen
