10-27-2020
08:47
11:17
10-27-2020
08:47
11:17
The last couple of runs I've had, the GPS suddenly stop tracking after a minute of running. I've reset the device multiple times, checked my settings and always turn the battery saver off on my phone.
03-15-2021 07:39 - edited 09-12-2023 09:08
Hey @Srebro, welcome on board.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the following:
1. Remove the Versa 2 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa 2.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa 2.
Best Answer10-27-2020 11:16
10-27-2020 11:16
Hi there @EivindHamre, welcome to the Community Forums. I'm sorry to hear that the connected GPS on your Versa 2 stops working after a minute of running, I understand where your concern is coming from. Thanks for already trying to solve the issue prior to posting here, I'll be glad to continue to help you.
Verify the following requirements; then try the troubleshooting steps if necessary:
See if GPS connects after each step
Let me know how it goes.
Best Answer03-14-2021 07:17
03-14-2021 07:17
Doing same route for months same same rutine and nothing above apply to my problem, Versa 2 just stop communicating with my Android phone.
Best Answer03-15-2021 07:39 - edited 09-12-2023 09:08
