01-26-2021
15:41
16:43
RicardoFitbit
01-26-2021
15:41
16:43
RicardoFitbit
My versa 2 took ages to pair to my phone after the update. I finally got that done and now the syncing stops working intermittently and when it is working will only sync when I go into the app and tell it to. The notifications from my phone aren't coming through either. Its an android phone.
Does anyone know how to fix this??
Hello @Mariemurph33, welcome to the Community Forums.
First, I appreciate your effort and patience for troubleshooting this situation before posting over here, I totally understand how frustrating this matter can be for you. To fix the connection difficulties you're currently experiencing with your Versa 2, I recommend you to check how the syncing procedure works here and see if there's a missing requirement on your mobile device that's preventing the syncing procedure to be completed.
Then, you can move forward and try the troubleshooting steps that are specified on: Why won't my Fitbit device sync? and let me know how it goes.
Let me know if further assistance is needed and if you have any additional questions.
