03-21-2024
05:34
08:33
03-21-2024
05:34
08:33
my versa 2 screen randomly started flickering today. I've read the forums and have restarted 4 times and changed the clock face 3 times like others had suggested with no resolution. Any other suggestions? The device is still working properly, it's just the display screen.
03-22-2024 08:37
03-22-2024 08:37
Hi there, @Jesse-Hamner. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention, for the troubleshooting steps you've tried, and for the image attached. I'm sorry to hear that the screen of your Versa 2 is still corrupted. I understand where your concern is coming from, I will do my best to help you with this!
As our last resort, I'd recommend performing a factory reset. Important: Take in consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
With that being said, please try the following steps to complete the factory reset:
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Best Answer03-22-2024 08:37
03-22-2024 08:37
Best Answer03-22-2024 18:58
03-22-2024 18:58
Thank you! The hard reset fixed the issue!
03-23-2024 07:32
03-23-2024 07:32
@Jesse-Hamner I'm glad to hear that the factory reset solved the issue. Thanks for sharing the outcome!
In case you have some spare time, I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
Best Answer04-09-2024 23:34
04-09-2024 23:34
Thank you.
I woke up with this same issue today - now sorted.
Best Answer04-10-2024 03:08
04-10-2024 03:08
@homewalker23 Welcome on board! I'm pleased to hear that your issue is now sorted.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
Best Answer04-10-2024 05:12
04-10-2024 05:12
Unfortunately that fix was temporary for me. It only lasted a few days and is back to the same white lines on the screen. It stared again 3 days ago. Still continues to charge and work appropriately, it's just the lines on the screen that won't allow me to see the time, messages, or set and turn off alarms.
Best Answer04-10-2024 06:22
04-10-2024 06:22
Best Answer04-10-2024 19:47
04-10-2024 19:47
This is happening to mine also. I’ve tried resetting but it’s still doing it randomly.
Very frustrating. I’ve only had the watch about 8 months!!!
