06-17-2024
03:29
03:52
06-17-2024
03:29
03:52
My watch started doing this yesterday. I’ve noticed a few other posts where it seems others are also having this issue. Has been anyone been able to fix it? It will clear and I can see my steps but then this will show again. Also battery is not lasting very long.
Hi there, @Jamiebrooke. It's nice to see you around the Fitbit Community Forums. I'm sorry to hear that the screen of your Versa 2 is acting odd. Thanks for the image attached. I understand your concern, I will do my best to help you with this!
If you haven't done so yet, please try the steps below:
If the above doesn't work, please restart your Fitbit device once again as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Regarding the battery draining quickly, please try the following steps:
Nonetheless, please bear in mind that as all rechargeable batteries age, they deteriorate to some extent and an older device will need to be charged more often than a new one. The best way of minimizing this effect is to avoid deep discharges of the battery. To maximize the overall life of your Fitbit device's battery, ideally keep it between 20-80%. Many people find that a daily battery boost works best ( e.g. giving it a 15 minutes charge while you are showering in the morning).
Best AnswerI have tried all these things. My screen is still messed up. Any other
suggestions?
