03-05-2021 03:40 - last edited on 03-07-2021 19:02 by LiliyaFitbit
Hi my fitbit has a flashing screen. Tried uninstalling and reinstalling. Turned bluetooth on and off. Phone found device and sent a 4 digit code but I can't read it off the flashing device. Last week it had the red x with try re syncing. Managed to fix that an d now have this new problem. Thank you
03-05-2021 06:37
03-05-2021 06:37
Welcome to the forum. I'm sorry to hear you are having an issue with your Versa 2. The first thing I'd suggest trying is doing a reset by holding down the button for 10+ seconds until the screen goes dark and the Fitbit logo appears. You may need to try this a couple of times to get it clear the issue. Fingers crossed that does the trick for you.
Best Answer03-09-2021 10:35
03-09-2021 10:35
