01-14-2020
08:12
05:18
JuanJoFitbit
01-14-2020
08:12
05:18
JuanJoFitbit
I purchased a Versa 2 a couple months ago. I thought it was great that I could record my activities and see summaries following the workouts on the watch face. I immediately noticed my heart rate was hitting an extremely and potentially dangerous peak rate which caused me to see a cardiologist. After doing an echo stress test and wearing a heart monitor for a week I found out the heart rate monitor on the Versa 2 is extremely inaccurate. There was a 30-40 bpm difference in what the cardiologists heart monitor recorded and what the Fitbit recorded. I’m extremely disappointed in the Fitbit inaccuracy as well as the anxiety and cost associated with having to see the cardiologist only to find out everything was normal. Anyone else having this issue?
05-03-2021 06:08
05-03-2021 06:08
This is me exactly!
05-12-2021 10:26
05-12-2021 10:26
I'm having the same problems. Initially used during Schwinn Airdyne exercise. The hr might initially popup at 83, then it wouldn't display. Got off the bike and my used my pulse rate device and it was over 150. I thought the arm motion might be the problem.
I now use an Echelon spinning bike. Same problem. Watch basically shows around 84 , goes blank, shows 120+ then drops to 83, goes blank, then shows 156 (BTW- 156 is my 100% hr for my age). Very dangerous!
And where is the Fitbit moderator? Where is the support help?
05-12-2021 13:05
05-12-2021 13:05
Didn’t work for me. My heart rate is showing slower even during intense workouts.
05-12-2021 19:13
05-12-2021 19:13
05-12-2021 19:41
05-12-2021 19:41
Mine too. I bought a Versa 2 after the HR failed on my versa after about 3 years. This one is terrible. I wear a second monitor at Orange theory and the rate is 30-40 beats slower on my versa than the OTF burn. Previously they were exactly the same. 2000m on the rower and it says I at 86 bpm. I rebooted and it is only worse.
05-13-2021 05:10
05-13-2021 05:10
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC6107736/
Here's a meta-analysis that looked at 67 different studies to examine the overall effectiveness of fitbit as a device. Here's what the researchers concluded:
"Other than for measures of steps in adults with no limitations in mobility, discretion should be used when considering the use of Fitbit devices as an outcome measurement tool in research or to inform health care decisions, as there are seemingly a limited number of situations where the device is likely to provide accurate measurement."
I've been looking into ppg technology in hopes of making the watch work because having to spend ten minutes troubleshooting my watch during my workouts was getting frustrating. Clean it - switch the hr on and off - hard reset - reposition, over and over and over. Doesn't put you in a good frame of mind for exercising. It doesn't look like there's a guaranteed way to make it work. The only way to improve it at this point is to innovate. An internal QC device that can measure the strength of the signal, maybe. Something that could tell the user the watch is picking up a poor hr signal? I don't really know what can be done to fix it.
05-13-2021 06:00
05-13-2021 06:00
05-13-2021 09:22
05-13-2021 09:22
Thanks for the link JustM.
I did a Tabata Spin workout this morning. I had reset and cleaned the watch, and positioned the band according to the two fingers distance exercise suggestion. Initially, the readings appeared accurate, and it displayed in the 140's.Good. However, later it wasn't picking up/was wrong readings. Tabata workouts raise the hr for 20sec on, then you recover for 10 sec, then repeat. I wasn't getting readings. I adjusted the band to three fingers above the wrist bone. I got accurate readings.
Suunto site says: During exercise
Test the fit – the key is to wear the watch as high up on your wrist as possible, and to prevent it from sliding down during exercise. A good indicator is to wear it about 2 fingers above your wrist bone. Again, make sure you wear the watch tight and evenly against the skin.
Wear the watch higher than your wrist bone.
This is useful especially for those who have skinny wrists, as you need to find the areas of skin with more blood flow in order to properly use the OHR.
Optical sensors measure pulses of blood flow directly; they are looking only at the total reflectivity of a small area of your skin.
Nice article: https://allthestuff.com/wrist-heart-rate-monitor-accuracy/
I have thin wrists. Placing the watch higher up- maybe five inches may be a solution. Echelon et al sell forearm mounted watches.
Maybe we can request Fitbit to design/sell a band to wear the watch on the forearm.
05-13-2021 13:28
05-13-2021 13:28
I find it hard to imagine fitbit didn't know about this and counted on it being a minority who realise and are bothered enough. It's clear reading posts on this that folks get put off with all the stock replies by customer support. They either can't or won't do anything about it. I can imagine google has a significant interest in the aggregated data and if they realise it is inaccurate, then they may be motivated to try and do something.
05-13-2021 14:24
05-13-2021 14:24
05-28-2021 02:20
05-28-2021 02:20
I also have experienced the same. First off, it's not difficult to take your own heart rate which I have done many times before purchasing the Fitbit. After purchasing the Fitbit I regularly check it while on treadmill and while the treadmill and I record the same BP reading the Fitbit continuously records an erroneous result, for the record i continueually dry my wrist and the sensors. It also records an erroneous result for my milage and I assume calories burned as well as step.As an example, I can put 4 miles (treadmill results) in on the treadmill doing interval training for 70 minutes and the Fitbit will record significantly less miles. In the same day, my husband walks a small golf course and is able to record 8,000 more steps and many more calories than I after a my workout and I am the one that had a 70 minute elevated HR. Last time I check golf wasn't a strenuous activity. This thing is a gimmicky. So dissatisfied.
07-20-2021 07:02
07-20-2021 07:02
Can you tell me please if your tattoos are on the back of your wrist? My heart rate has gone bonkers the past week and although I have no tattoos on my wrist, I have a very bad skin rash where the sensors are. Thanks so much
07-20-2021 07:19
07-20-2021 07:19
07-20-2021 08:25
07-20-2021 08:25
07-20-2021 11:26
07-20-2021 11:26
Oops I clearly didn't do this reply thing correctly...sorry 🙈
Someone on page 1 had said they had tattoos and it interfered with the readings. I thought I was replying to him. I did a reset and it's still reading really high. 😭😭
07-20-2021 13:38
07-20-2021 13:38
I had this too but it would go both ways, way too low sometimes when I was exercising and others off the charts. There is a new firmware today to hopefully fix the inaccuracies. I talked to support multiple times and they said it was being fixed. Fingers crossed.
07-27-2021 15:52
07-27-2021 15:52
I've recently taken firmware update 35.72.1.15 and initial signs are very encouraging. I've no idea if the update claims to make any improvement or not. It may be a coincidence but I've been cycling a lot recently and always double strap - polar with HR strap (because fitbit unrealiable) and the fitbit to capture the GPS/exercise session. All rides since the firmware update are much closer to the polar recorded HR (which I trust heavily) than previous. Just seems to be a huge improvement. Anyone else observing similar?
07-30-2021 01:27
07-30-2021 01:27
07-30-2021 18:59
07-30-2021 18:59
I literally laughed out loud. I shouldn't have to wear a WRIST watch up around my forearm for the HR monitor to work correctly. Obviously, the folks at Fitbit don't give a crap about this problem that has been going on for at least 3 years. (Some of these threads date back to 2018.) I can tell you this: I will never buy a Fitbit ever again.
07-31-2021 01:06
07-31-2021 01:06
I agree. But some strong signs that a latest firmware update has helped a lot. I've been keeping an eye on it and it's encouraging. No confirmation from Fitbit that something in latest update is intended to help, so could be other factors coincidentally in play. I wear a polar strap when I ride (because of Fitbit issues); the two are much closer since the update. Plus I have been wearing it normally - on the wrist. I have a versa 2. Don't know if same update available on your device.
