10-12-2020
05:45
06:24
JuanJoFitbit
10-12-2020
05:45
06:24
JuanJoFitbit
Hey guys! I have two questions:
1. Why does the HRV only track when sleeping at night and not during the day at all?
2. What is a good range for HRV when sleeping? Mine is 20 every night and I have no idea if that is good or bad.
05-29-2021 20:45
05-29-2021 20:45
I'm at 16. Wondering if better sleep and hydration will help.
Best Answer07-21-2021 00:34
07-21-2021 00:34
Yes, they will.
An hour of strenuous exercise will initially decrease the HRV, but after a second night of good sleep and relaxation during the day, it will begin to creep up. After a prolonged period of exercise, rest, exercise, rest, the figure will rise considerably. This is related to why medics tell you to get more exercise and get more sleep.
07-24-2021
01:00
18:07
DavideFitbit
07-24-2021
01:00
18:07
DavideFitbit
My Fitbit app only gives 1 week of info. I notice you have months worth. Do u have the premium version?
Do u need the premium ap to get more than 1 week of data Robert?
07-24-2021 05:18
07-24-2021 05:18
10-03-2021 11:10
10-03-2021 11:10
LOL, mine was 9 last night. See you in heaven.
10-13-2021 18:21
10-13-2021 18:21
Thank you for your insight! Feeling much better about what appears to be randomly changing numbers. 😩 Doing a trial of premium.
10-14-2021 01:42
10-14-2021 01:42
11-09-2021 14:31
11-09-2021 14:31
So I’m 57 and consider my self healthy I walk about 44 miles week eat healthy and have a BMI 25 why does sleep hrv show 20 is this ok?
Best Answer11-13-2021 06:54
11-13-2021 06:54
HRV metrics are only meaningful if taken “at rest”. Breathing rate affects the HRV metrics, as does movement, ambient temperature and believe it or not, one’s state of sleep, hydration and food.
it’s best to use a reference measurement at the same time of day, the best is first thing in the morning, before breakfast - it’s a typical glucose fasting state.
Best Answer11-13-2021 06:56
11-13-2021 06:56
It’s important go get the metric you are using. They are not all the same. A number is meaningless try and focus on the change.
Best Answer11-13-2021 23:52 - edited 11-14-2021 22:56
I think Richrv’s comments are excellent. I got all excited about HRV and have been tracking it since earlier this year to see if I could improve it. And yes, it can be done but it is next exactly as expected. The number varies greatly and any one day or period could be influenced by something you are not aware of at the time of the reading(s) or may never know.
Here are two HRV charts in Excel up to 11/4/21 to see my measurements over 2021 from my Versa 2:
A couple notes from observations since tracking HRV:
As you can see from my HRV charts, it goes up and down and I can’t always determine the reason. Although, I sometimes question the accuracy and integrity of data from my Versa 2, I don’t know. I am just going with the number when it is provided(Currently my Versa 2 hasn’t provided an HRV reading in over a week due a backend problem with Fitbit systems). It seems like there are a lot of backend tweaks happening that cause issues with the device performance. But in general, it is a reference point.
My takeaway is the same and not focus too much on HRV. Try also using another basic fitness metric for a reference point about yourself. How many pushups can you do or how long does it take you to run a hundred yards or a mile(s)? For me, even though my HRV has been going down lately, I am improving in other areas. So pick something to track and work on improving it. Improving a physical metric is much more stable and will provide another indicator about your health besides a variable HRV metric that is hard to understand why you get the number you get.
I hope it helps...
01-01-2022 15:37
01-01-2022 15:37
Here are some very basic absolutes for me.
1. More than 3 ounces of red wine will lower my HRV
2. Beer always lowers my HRV
3. Over exertion always lowers my HRV
4. A rest day always increases my HRV
5. I use a Charge four Fitbit, and the longer I sleep straight through the night, the better my score. If I have insomnia, and finally get back to sleep for three or more hours, I’ll get a decent But not great HRV reading.
6. Losing weight helps HRV a bit over time.
Alcohol plus a short nights sleep is the worst combination for me when it comes to HRV score on the charge 4.
08-27-2022 08:01
08-27-2022 08:01
Do you wear your band tightly? I am reading HRV threads because I thought I was on the verge of a heart attack based on how low mine is (11-17).
11-17-2022 21:32
11-17-2022 21:32
Mine too. 12, 14, 11
... Wtheck
11-23-2022 23:24
11-23-2022 23:24
All these people reporting low numbers... at least you know you're not alone! When your number is high, you think, am I the only one? Using FitBit's RMSSD measure of HRV, I usually come in around 110 and have peaked at 140. I'm in my 50's. I'm reasonably fit but no athlete. Makes me think a pinch of salt is in order.
A partial explanation is that is that higher heart rates produce lower HRV scores. In principle, device makers could eliminate the influence HR has on HRV, but I don't think any of them have. FitBit hasn't. It's one reason my HRV is so high: I often wake to an HR of 42 to 50 bpm, and lower HR means higher HRV.
Do factor your HR in to any worrying you might be doing about your HRV.
Best Answer12-16-2022 16:01
12-16-2022 16:01
Late to the thread but wtw? My resting HR is 54. I'm reasonably fit at 61, fitbit says good to excellent cardio shape. My sleep number bed gives me a HRV average of 78, yet fitbit gives me an average of 28 with occasional jumps into the 80s for 1 night. Which is correct? 50 pts is a pretty big difference!
Best Answer02-09-2023 05:56
02-09-2023 05:56
Just in case it makes any other lowbies feel better...
My HRV is typically between 7-9. Once I got an 11 but that was "outside my normal range." I am 41 and have been a runner for 20 years. I do yoga on my off days, and meditate daily. My BMI is healthy at 5'4" and about 130lbs. do not think I'm dying. However, I've always had a very high RHR, averaging around 85 to 90. I avoid caffeine and other stimulants, but it's always been this way. I imagine this is why my HRV reading is so low, and makes me suspicious about the accuracy of the Fitbit HRV scanner. So don't despair - see a doc if you're worried, but I don't think Fitbit is the best gauge of health in this metric 🙂
02-17-2023 12:34
02-17-2023 12:34
mine says 8, so I think I am going to die any day now
