11-16-2022
12:23
15:56
11-16-2022
12:23
15:56
Screen is flickering. Sometimes I can see the screen and then it flashes and the screen goes black. Please help? I tried to restart but I can’t see the screen
Hi there, @Raymer. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
@Raymer I appreciate you had followed the tips and recommendations provided above.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon! 🙂
