06-19-2022
03:57
07:21
06-19-2022
03:57
07:21
Hi
I have a Versa2 and have only had it since April. My clock on my Versa is fast (varies between 1.5 to 2 hours). How do I fix it?
Thank you!
06-20-2022 07:24 - edited 12-19-2023 08:55
Hi there, @SRKGAKK. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
While reading your post, I was wondering what you mean by "fast" exactly? Keep in mind that your Versa 2 may show the wrong date and time if it hasn't synced or has been unpaired from your Fitbit account. Your Fitbit grabs the time of the device you're syncing with.
As @Guy_ has suggested, please see How do I change the time on my Fitbit device?
If by any chance, you're running into syncing issues, take a look at this help article Why won't my Fitbit device sync?
Hope that helps.
06-19-2022 06:25
06-19-2022 06:25
Hi @SRKGAKK - this may be a time zone setting issue.
In the Fitbit App, click profile photo, App Settings.
Turn off automatic time zone and location and set the time zone manually, then resync, it should set the time correctly.
Sometimes it may be necessary to restart the watch for the time to get set during syncing.
Afterwards you can turn automatic time zone [and location] back on.
Hope that helps.
