09-26-2022
11:31
12:07
09-26-2022
11:31
12:07
The moment that I start exercising my versa 2 comes up with stupidly high heart rate readings! Eg my pulse might be 90 but the watch will say 160! I’ve tried putting it higher up my arm, tightening the strap, cleaning the light sensors, not moving my arm but still the heart rate reading is miles out. Is the versa 2 really that bad?
09-26-2022 12:09
09-26-2022 12:09
Hi there, @RichDro. Thanks for stopping by in the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. I understand where your concern is coming from.
In addition to the steps you've done so far, I suggest trying the following:
Also, please see What factors can affect my heart-rate reading on my Fitbit device?
Hope this helps.
09-26-2022 12:09
09-26-2022 12:09
Hope this helps.
10-01-2022 14:50
10-01-2022 14:50
Hi, thanks for your help. I’ve done that and encouragingly the heart tracker worked properly in today’s spin class. Maybe the fix worked. Will monitor and report back.
10-04-2022 04:34
10-04-2022 04:34
@RichDro Awesome! I'm glad to hear that the steps did the trick! 🙂
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
Best Answer11-27-2022 14:18
11-27-2022 14:18
Any luck with this? After updating the watch to v72.1.23 it seem to properly monitor heart rate sometimes - spinning today it seemed about right, but a medium-intensity run on Thursday showed my heart rate at 177, which is ridiculously high (over 100% for my age/fitness level). So it's intermittent. This is a replacement watch too - the first had the same problem.
Best Answer11-27-2022 14:59
11-27-2022 14:59
No it’s still not working. In gym today doing warm up on bike. Pulse at c 90 but Fitbit said 140. After about 5 minutes it ‘woke up’ and started giving normal readings. This happens a lot - starts off with v inaccurate read and then 5-10 mins later it starts to give more accurate readings.
11-27-2022 18:58
11-27-2022 18:58
Thanks. After I posted, I went for a casual walk in the neighborhood and it showed 140 bpm for a short section of what was a very continuous pace. I give up!
