06-10-2023
20:02
08:06
06-10-2023
20:02
08:06
Initially, my Versa 2 was locked in the main screen and would only move to the Exercise screen when I pushed the left button. I wasn't able to select any of the exercise options.
I tried restarting it, then charged it, and it subsequently only showed the flashing Fitbit logo repeatedly. I tried charging again (it was already at 80%). A few minutes later, it showed a low battery with an exclamation point. Now it won't turn on at all. Help please!
06-11-2023 03:50
06-11-2023 03:50
Hi @IDMe It sounds as if it has died, unfortunately. If it is still under Warranty then contact Fitbit Support
Helen | Western Australia
06-11-2023 08:17 - edited 06-11-2023 08:17
Hello there, @IDMe. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
In addition to the steps you've done so far, I'd suggest trying the following steps:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa 2 from your phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
If none of the above seems to work, please follow @NellyG's advice and chat with us online or give us a call. Click here to get connected.
Best Answer06-13-2023 19:09
06-13-2023 19:09
Hi @MarreFitbit , thanks for the reply. I tried all the steps you listed, but it won't even vibrate when I hold the side button for 8 seconds (or longer). It doesn't appear to even allow me to do a factory reset. I will connect with you offline.
