Try disabling battery saving and clear cache
On the phone check battery optimizations [the options may be different in your version]
Best Answer@Goodwin1929 I would start with this help doc.
On some android phones power management for the Fitbit app needs to be disabled as explained in the android tips. No need to disable power management for the whole phone.
No if the tracker syncs when the app is open but not while the app is in the background, it usually is power management.
On some android phones if tge Fitbit app is in the front when the phone closes. The app gets put to sleep.
