05-24-2021 21:14
05-24-2021 21:14
Hi. My daughters Versa 2 is doing little more than keeping time these days, and wouldn’t even do that accurately today. She tells me she has tried syncing and a reset but at only 18 months old I’m not ready to upgrade the device. Any ideas on what I should be doing to try and get it working properly again?
thanks
05-25-2021 05:54 - edited 05-25-2021 05:55
I am having the same sort of problem and mine is about 18months old too. I am getting increasingly annoyed about it as it only seems to have happened over the last week. I spent 30 minutes trying to sync it this morning and well over an hour yesterday. It's also losing time as well as not syncing data. I shan't be getting another one unless this problem is fixed.
05-27-2021 04:23
05-27-2021 04:23
My daughter is a very tech savvy 13 yr old and was using every possible function on it when she first got the watch. I can’t work out if it is the user, watch or software. It started with just one or 2 apps being an issue but now seems to be all of them including time. Am wondering if a full factory reset is a possible solution but not sure how to do it. I’m noting position to replace the watch at this stage.
05-27-2021 04:35
05-27-2021 04:35
Beginning to think this is their way of forcing us to buy a newer on! Not happening... Will buy something else if they do not fix this . Mine only tells tie time and I have to press the but. ton to do so!
05-27-2021 04:38
05-27-2021 04:38
yes, if I were you I'd do that.
05-27-2021 05:00
05-27-2021 05:00
The same thing is happening to me! My heart rate sensor would not work, but everything else did, and it was hooked up to my phone Bluetooth. I used the supports chat feature, and the representative had me factory reset my FitBit, and now it won't connect to my Bluetooth on my phone at all. I reached out to FitBit multiple times, and the best answer they could give was that my watch was out of warranty, and gave me a discount code to get 35% off a new one. I refuse to buy a new one when it is their fault.
I have tried all of the resets, restarts, and installing that is possible, and nothing has worked. To say I am furious and irritated is an understatement. This is obviously a FitBit issue.
05-27-2021 05:04
05-27-2021 05:04
This is the concern I have is if I do the factory reset will it make things worse?
05-27-2021 05:04
05-27-2021 05:04
05-27-2021 05:06
05-27-2021 05:06
05-27-2021 05:07
05-27-2021 05:07
Not an option at the moment
05-27-2021 05:07
05-27-2021 05:07
It did for me. Everything on my FitBit was working, and it was connected to my phone. The ONLY thing was the heart rate was not detecting, and now that I did a factory reset, it wont connect to my phone AT ALL, so it is basically completely useless. I have been fighting with FitBit since yesterday and this seems like a global issue.
05-29-2021 09:24 - edited 05-29-2021 09:25
UPDATE: I am pleased to say that my Versa 2 appears to be back to running normally. To do it, I had to delete the Fitbit app from my PHONE, and then re-install it. I have tried fixing it so many times I can't remember whether I also had to press the button on the side of the watch - but I don't think I did, I think it was just a problem with the app rather than the watch itself. Here's hoping, anyway!🙂. I'll be interested to know if this works - or doesn't - for anyone else.
