Hi, @Hversa2 , on the Versa 2 , under your notifications settings, you need to choose a primary text messaging app - most popular messaging apps are available.
If you would like to get notifications from other messaging apps as well, under notifications choose “App notifications” and tick the check boxes to indicate which apps can send you notifications.
For example, for my Fitbit my choice for “Text Messages” is WhatsApp, but I also receive notifications from my phones sms messaging app by ticking that box under “App Notifications” . You can tick as many app notifications as you like.
Whenever you make any changes in your app be sure to sync your Fitbit.
I hope this helps. Welcome to the forums.
