Versa 2 not showing the correct amount of steps after syncing
ANSWERED
I am new to Fitbit .. I set it up but confused at how to navigate to all that is offered..I walked for 1 1/2 hours this morning..my fit bit showed I walked 7000 steps but when I go to the stats it says I walked 1608 steps..what am I doing wrong. Please help me..I want to get the most from my versa 2. Thanks for your time..Linda
1 BEST ANSWER
Accepted Solutions
Hi there, @Linda3591. Welcome to the Community Forums. Thanks for sharing the details about the issue with your new Versa 2. I understand how important is to you to get accurate data.
Please note what @JohnnyRow has mentioned. To make sure that your Fitbit app reflects the same data as your Versa 2, I recommend you to frequently sync the watch or after every workout you've done.
For more information, see the following help articles:
I've moved your post to the Other Versa Smartwatches board for organization purposes.
2 REPLIES 2
That is probably that your Fitbit has not synced since your walk.  When it syncs,  then the app should get updated with latest stats from your tracker.
