02-24-2021 12:00 - last edited on 02-25-2021 16:27 by LiliyaFitbit
Versa 2 not switching on. Been on charge over 24 hours and have tried holding back and bottom button. Also held all 3 buttons and nothing
02-24-2021 21:52
02-24-2021 21:52
A versa 2 only has one button so you must have a Versa
Seems like this is a common issue recently. Possibly due to a recent update, as it was working before.
In which case its probably best to inform Fitbit Support directly. They may be able to help you.
But try this first
To see what's happening with the charge
Connect the charge cable to the watch and plug it into a PC USB port
The PC should announce a connected device with a sound, it means its connected and charging [if there is no sound, either the volume on the PC is low, or off, or the watch is not properly connected to the charger]
if the PC then announces a disconnected device with another sound, it means the watch battery is either flat or the watch is dead
anyway wait 10 minutes [for battery to get to 5%] if the watch or battery is not dead it will announce device connected again [the watch may also wake up]
if after an hour there is nothing on the watch face try starting it by pressing a button for a few seconds and waiting for the logo to appear or restarting with the buttons
if nothing comes on the screen, either there is a screen or button fault or the watch is dead - but wait
Check the button start procedure, to make sure you are actioning it properly, and that the button clicks |
16:26
07:16
02-25-2021
16:26
07:16
Welcome to the Fitbit Community, @SuziSmo. It's nice to see you around and thank you for your help, @Guy_.
@SuziSmo Thanks for the details shared in your post and for already trying to resolve the issue. Besides the helpful tips shared by @Guy_, you can try the complete troubleshooting instructions at Why isn't my Fitbit device's battery charging?
Hope this helps!
Best Answer02-26-2021 13:25
02-26-2021 13:25
Hi
Thank you both for your reply. Really helped and got as far as managing to charge it.. Issues now though with not being able to get past Lignite to pair it with my phone
Best Answer02-26-2021 13:27
02-26-2021 13:27
Thank you for your reply. Really helped and managed to charge. Now and get past Lignite to pair with my phone 😔
18:26
07:16
02-28-2021
18:26
07:16
Thank you for your reply, @SuziSmo.
I am glad to hear you were able to charge your device. Thank you for your time and efforts. I understand how you are feeling about the issue with pairing your device and recommend following our troubleshooting instructions at Why can't I set up my Fitbit device?
Hope this gets you back on track!
