Versa 2 recording only sleep patterns
Basic sleep pattern 80% of the time whith new Versa 2, older Versa 2 was no problem. 2 new Versa 2 that I bought not training  sleep only  basic and I'm having to send them back.
2 REPLIES 2
What changed other than the watches? Did you change the original band? Wear it differently? Install the latest firmware?
Something changed.
Hi @John291, I'm glad you came back to the Community. @SunsetRunner, thanks for the help.
Thank you for the information provided regarding the sleep stages. I'd recommend you check if you have the Heart Rate tracker on and also try a restart on your device
Also to have sleep stages recorded on your Fitbit App, you must have at least 3 hours of continuous sleep. For more details check this article.
Hope this helps.
