08-08-2022
23:30
04:41
08-08-2022
23:30
04:41
This is my 2 Fitbit product in less than 6 months and to say I'm not Happy nor Pleased with this product. Fitbit needs to fix this issues with there products there selling. Screen turning green with lines and blank. What use is the product if you can't use it. After this issues and I can't get the product to work properly like it should, I'm done with Fitbit products why should I keep wasting my money.
#unsatisfiedcustomer#
Hi there, @Flodavis1. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Versa 2. We‘re taking your comments and sentiments in regards to our products into consideration.
Regarding the screen not working, please restart your Versa 2 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
As for the battery draining too fast, please note that as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Best AnswerTotally with you here. Mine is doing exactly the same with the screen but is a bit older so obviously the standard reply from Fitbit will be we-can’t-fix-it-but-here’s-a-discount-on-another-of-our-products-which-will-soon-go-**ahem**-up!
oh and yes Fitbit, I have re-paired, charged, changed the clock face etc.
