09-05-2020
13:13
14:21
09-05-2020
13:13
14:21
My screen is having serious issues. It is going from green to grey with lines going across like a TV which is having problems with its vertical hold. At first I tried re-starting it which did work for a while, I have tried a factory reset which worked for a while and now unpaired it from my phone which did work before but now will not. The watch is now useless. What can I do now?
Mine began doing the same thing a few days ago. The screen is white and flashes. All of the restart procedures didn’t work. Since I bought it in January it is still under warranty so they are sending me a replacement. Basically, when this happens there’s nothing you can do to fix it.
