08-16-2023
16:32
06:28
08-16-2023
16:32
06:28
My screen started by what I can only describe as strobing. Ie horizontal lines with the usual face/ text not visible, havevtried rebooting and it works for a short time then starts again
08-17-2023 00:57
08-17-2023 08:28
08-17-2023 08:28
Hi there, @Pim100. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work, as @Guy_ has suggested, try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best Answer08-20-2023 08:50
08-20-2023 08:50
Have tried the screen doesn't stay stable enough to switch click faces
