07-07-2023 06:20
07-07-2023 06:20
I’ve just noticed my versa 2 screen is loose - it literally just popped off as I was sitting at my desk. Anyone know if this can be fixed? I have had it just over two years so it’s out of warranty. The screen still works.
07-07-2023 06:36
07-07-2023 06:36
Hi @NicolaJGam there are no repairs for these devices. You might find a protective band cover on Amazon that would encompass the pebble portion and allow you to continue using it. If you went that route, just don't get it wet, as it's not a waterproof band.
07-07-2023 06:36
07-07-2023 06:36
07-07-2023 07:26
07-07-2023 07:26
Thank you. I’ll take a look fit a cover.
