11-27-2019 12:00
11-27-2019 12:00
Hello Everybody,
i just got my Versa 2 and i would like to keep on my left wrist but with the button facing the hand so is easy to use the one button.
I searched in the forum but I didn't found nothing about it.
Any clew?
Thank you
11-27-2019 13:53
11-27-2019 13:53
You can not reverse the display.
Best Answer11-27-2019 13:53
11-27-2019 13:53
Best Answer11-27-2019 14:32
11-27-2019 14:32
That's a bummer, it will be much easier push the button if was on the right since my Versa is on my left hand
11-27-2019 14:36
11-27-2019 14:36
@Pislui I wear my Versa 2 on my left wrist and push the button with my right thumb. It is a completely natural movement for me. Might be because I have done this for many years with Fitbit trackers on my left wrist. Just one opinion.
Laurie | Maryland
Best Answer11-29-2019 11:07
11-29-2019 11:07
For the placement of the button is awkward. I have to bend my wrist in a way that is uncomfortable in order to press the button and still see the screen. This limitation is not good for individuals with arthritis.I just returned a versa 2 that I bought for my father for this exact reason.
12-26-2019 10:36
12-26-2019 10:36
I agree. Every other digital display I own rotates, including my other $40 dollar fitness trackers. Not sure why they can’t add this simple feature. The button on the left wrist is in a horrible to reach position.
03-09-2020 08:06
03-09-2020 08:06
I too was surprised to find out rotating the screen wasn't an option. When wearing watch on left wrist, I find it awkward to press the button with my thumb and would prefer to use my finger instead. Can we get a fix for this?
09-28-2020 13:24
09-28-2020 13:24
Just bought the versa 3 and I think this button placement is really annoying it's really to hard reach and press on the left side, can we please get a simple fix for this? Like rotate directly from the app? It's not much to ask for..
