10-06-2022
08:16
09:18
10-06-2022
08:16
09:18
Following the recent firmware update, my Fitbit has so far developed 2 problems:
I cant stop my morning alarm by touching the tick on the screen, a red cross is displayed and i have to snooze it with the side button.
My screen shuts off and only comes bac on for a while if I dock it in the charger despite a good and charged battery.
Anyone else?
10-06-2022 09:19 - edited 11-21-2023 05:32
Hi there, @Bitfit_Warrior. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2. I understand where your concern is coming from.
Please restart your Versa 2 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
Hope that helps.
10-06-2022 10:37
10-06-2022 10:37
Thank you, no, no luck with either and although I can tell it is on, I now cannot do anything to make the screen respond.
10-08-2022 04:15 - edited 11-21-2023 05:14
@Bitfit_Warrior I appreciate you had followed the tips and recommendations provided above.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon! 🙂
