09-01-2020
05:40
11:50
09-01-2020
05:40
11:50
Hi all I hope you can help. My Versa 2 is stuck on ‘set up wallet’ screen. I can not swipe up or down. The button is not working either. Is there a way I can fix this
Hi there @Moona58, welcome to the Community Forums. I'm sorry to hear that your Versa 2's screen is stuck on "Set up Wallet", I'll be glad to help you with this.
If you haven't done so yet, I'd recommend trying the steps below:
If the suggestions don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
I'm looking forward to your response, keep me posted.
Hi there @Nevsin, welcome on board. I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected. I'd suggest to share this community link (thread) so our Support Team can be aware of all the steps you've done already, this way you can also avoid repeating yourself again.
We hope your issue is solved soon.
Best AnswerI've contacted fitbit about this issue... they DID NOT help. I hope that you had better luck!!!
Best AnswerFound out today there is a very simple solution to this problem after trying everything on the internet & Fitbit Customer service for 3 days. All you do is add a card to your wallet through your app. The card will then show up on your watch face. Go to a store and purchase something and use your watch to pay. It instantly unlocks your watch!
Best AnswerI am having same issue as many others with Versa 2 that Screen is stuck on Set Up Wallet AND the side button on left side is not working. What are the options to fix this issue? And is there a button on the back of Versa 2?
Best AnswerAll you do is add a credit card to your wallet through your app. The card will then show up on your watch face. Go to a store that has tap option on the credit card machine and purchase something. Use your watch to pay. It instantly unlocks your watch!
