06-01-2022
12:35
08:22
06-01-2022
12:35
08:22
Hi
My versa has a green screen have tried to force reset and just goes back to a green screen. Still tracking just can't use it for time etc 🙄
Hi @Jewelsjulie - it just might be a clock face issue, try a swipe of the face to the left, also try with double tap first.
If it is still green then it may be a watch fault.
Try chatting with support via the Fitbit App, click profile photo, Help & support, Contact Customer support they will help you do a factory reset.
If that doesn't work and it is still under warranty, 1 to 2 years depending on country law, take it back to where you bought it for replacement.
Hi there, @Jewelsjulie. Welcome to the Community Forums. Thanks for trying to troubleshoot your Versa 2 as suggested by @Guy_.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
