10-12-2019
03:05
08:06
AlejandraFitbit
10-12-2019
03:05
08:06
AlejandraFitbit
Since owning the Versa 2 for 2 weeks, when I'm outside the screen is very dim and unreadable. I have looked at sleep mode/auto dim settings- Max normal and Dim nothing fixes this. Can the auto light adjustment be turned off and I manually control my Versa 2 brightness settings? it really is impacting my experience and use of the smart watch.
10-12-2019 06:53
10-12-2019 06:53
@danielttt Have you tried restarting your Versa? Hold down the button on the left for 7+ seconds. See if that fixes it. My screen is easily readable outside and it’s set to normal.
10-12-2019 06:53
10-12-2019 06:53
10-12-2019 07:01
10-12-2019 07:01
@Heather-S, Thank you for your reply, Yes i have tried this multiple times. I researched possible fixes and so far nothing fixes the Dimness issue while outside. My Wife also has the exact same Versa 2 and hers does not Dim at all when outside. I checked we had the same settings on Auto Brightness/ sleep mode etc and still my Versa 2 is pretty much unreadable when outside. My none technical opinion is- the sensor which dictates the light level is too sensitive and reducing the screen brightness level too much.
Unless anyone from Fitbit Tech team can advise an alternative solution?
Thanks again @Heather-S
10-12-2019 07:05
10-12-2019 07:05
@danielttt Sorry to hear restarting didn’t work. I have flagged a moderator to come assist and open a support ticket for you. Best of luck!
10-12-2019 07:09
10-12-2019 07:09
Thank you again @Heather-S much appreciated, have a great Saturday. Hopefully the moderator can assist this glitch in what seems to be a great product overall.
10-13-2019 08:08
10-13-2019 08:08
Welcome to the Community, @danielttt and @Heather-S, thanks for the input.
I appreciate all the efforts in trying to fix this brightness issue. Since the steps you tried didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
In the meantime, let me know if you need anything else. 🙂
10-13-2019 08:11
10-13-2019 08:11
Thank you Alejandra-
I appreciate your support.
10-26-2019 20:51
10-26-2019 20:51
Hello,
I'd like to join the conversation because i've got the same problem. My fitbit versa 2 is very dim, while my mom's work flawlessly. I'm thinking this is a hardware problem, actually. It seems the light sensor is bad.
Have you got any news about your watch? Is there a software update that fixes it?
I've been using my cellphone to check the time when I'm outside because the watch on my wrist is bad.
12-29-2019 14:57
12-29-2019 14:57
Same issue with my new Versa2. Was fine then all dim/grey today. My settings for brightness do not have an auto feature, just dim bright and normal. It was a gift, must I return?
12-29-2019 21:07
12-29-2019 21:07
01-04-2020 18:32
01-04-2020 18:32
+1 for this issue - happening to me too. Can’t read the screen in sunlight, tried waiting for the sensor to wake up and brighten the screen - nothing happens. Check it again in 5 mins and viola, the screen is now suddenly bright.
Fitbit, any official stance on this?
01-05-2020 00:27
01-05-2020 00:27
01-05-2020 04:21
01-05-2020 04:21
01-11-2020 05:15
01-11-2020 05:15
Take it out of sleep mode
01-13-2020 14:07
01-13-2020 14:07
Appreciate the suggestion, but sleep mode is not on and not the cause of this issue.
I'm into my 4th chat with fitbit now, and have just sent through photos of the issue - even with brightness set to max the display shows like this:
You can see the display is on, it's just incredibly dim. It's as though the brightness detector is doing the opposite of what it's meant to - dimming the screen in bright light.
Hopefully I get the green light from fitbit to return this one soon and get a replacement.
01-15-2020 10:18
01-15-2020 10:18
I have the same problem as cmcpha01. The screen is unreadble outside in bright light, and I agree - it seems like the sensor is doing the opposite of what it should be doing, and dimming the screen further.
Auto-dim works fine indoors and in the dark. Just not outdoors. Frustrating.
01-15-2020 10:20
01-15-2020 10:20
I just realized this is a 'Versa 2' thread -- I have a 'Versa 1'. It's been working fine for about a year - this problem just popped up recently. Perhaps the last firmware update.
01-15-2020 10:22
01-15-2020 10:22
I feel your frustration! After sending through the photos to fitbit they’re replacing my versa 2, so seems to be the best course of action if you have this issue.
02-04-2020 05:33
02-04-2020 05:33
Versa2 dim problem I have it to,and absolutely no one will help me I have emailed texted did community post and did messenger with Fitbit, they will NOT do anything to help there customers, they will send you a refurbished one that is also damaged,and there update is what happened to mine.I have nothing good to say about this company anymore and back when I started with there alta and then the versa it was great, but did an update and my fitbit went down,sent me 2 refurbished ones and both JUNK!!!!but they keep giving me the run around,even asked for a supervisor but would not give me one,choose another company that cares about there customers,fitbit DOES NOT!!!!!!
02-04-2020 05:54
02-04-2020 05:54
