05-12-2021
20:09
07:16
05-12-2021
20:09
07:16
The screen won't respond to touch. I am unable to use the watch. I have already tried the recommendations to restart the watch and change the clock face to a fit bit provided one. These interventions did not work. What is the next step to make the watch work?
05-12-2021 20:20
05-12-2021 20:20
Having the same issue, cant even do a factory reset because the screen wont let me swipe!
Best Answer05-12-2021 23:34
05-12-2021 23:34
That happened to mine a two days ago. Fought with it of 50 minutes to hour to get it to shutdown. Gave five minutes hoping it just needed to clear it’s memory to restart fresh. Didn’t help. Didn’t wear for a whole day and somehow it half way corrected itself or so I thought. Can swipe right to see apps. Can swipe up to see activity. Can’t swipe down to see notifications and touch screen continues to mess up trying to input my unlock pin. Had my versa 2 since late 2019 and it worked amazing until recently. It’s sad. I have really enjoyed seeing it track my days with doing two jobs. The steps really get up there. Hope there is an update to fix this sometime soon.
05-13-2021 07:15
05-13-2021 07:15
Hi there, @ahleese @SamP147 @DatDysonKid. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 smartwatches before reaching out. I understand how you must be feeling.
Since you've exhausted all troubleshooting steps for this issue, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
Best Answer05-13-2021 07:30
05-13-2021 07:30
I am having the same issue
Best Answer05-13-2021 07:39
05-13-2021 07:39
Hi there, @krystal.m. Welcome on board.
If you're having the same issue, please restart your watch as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
05-13-2021 07:41
05-13-2021 07:41
05-13-2021 08:19
05-13-2021 08:19
Thanks for your suggestion, but I was on hold for over five minutes yesterday when I called!!
Best Answer05-16-2021 12:01
05-16-2021 12:01
Hi all,
After updating my tracker to the newest OS and restarting my watch one more time (held down the side button until the screen went dark), it started working. Hope this helps others!
Best Answer05-16-2021 12:28
05-16-2021 12:28
Has the clock face thing worked for anyone? Support had me do a factory reset, which made mine even worse. It was pretty much unusable already though. They didn't suggest trying a diff clock face. I'm using a different tracker rn.
Best Answer05-16-2021 13:16
05-16-2021 13:16
Made it worse
Best Answer05-16-2021 13:17
05-16-2021 13:17
@krystal.m Thanks for reporting.
Best Answer05-16-2021 13:26
05-16-2021 13:26
Actually, their 35% off offer isn't bad right now. Can get a Sense under $200 or a Versa 3 around $160.
Best Answer05-16-2021 14:10
05-16-2021 14:10
Changing the clock face help a little bit. Screen is responding but swiping down to see notifications on my original clock face still isn’t working. But that suggestion did help so I am still able to use my Versa 2 for a while. But the fact that with any clock face this issue can happen to anyone is still quite concerning.
05-16-2021 15:57
05-16-2021 15:57
Thanks. Guess it's worth a try before just pitching mine.
