09-26-2022
14:26
06:16
09-26-2022
14:26
06:16
My FitBit is a little over a year old and has quit scrolling. I’ve rebooted it many times and updated the most recent update and none of this fixes the problem. Is there a fix or is this broken?
09-27-2022 01:29
09-27-2022 01:29
Been having the same problem with my versa2 for the last 2 days! Reset multiple times, and even did “forget this device,” literally just upgraded 72.1.23 yesterday. Maybe a glitch?
09-27-2022 06:20 - edited 11-21-2023 05:57
Hi there, @Dennavs @Afuges. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 devices before reaching out. I understand where your concerns are coming from.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
@Dennavs On a side note, please make sure that your Versa 2 has been properly updated to version 72.1.23. To do so, in the Fitbit app, tap the Today tab > your profile picture > your device image. The firmware version number appears under your device's name. For more information, see How do I update my Fitbit device?
Hope that helps.
09-27-2022 06:42 - edited 10-07-2022 12:00
Thanks for these suggestions but, sadly, none worked. I changed the clock face, restarted it, and checked that the current version is installed. It still won’t scroll. Any other thoughts? I hate to have to replace it when it works fine otherwise but I use all the features provided by the scroll! @MarreFitbit
10-05-2022 19:04 - edited 10-07-2022 12:01
Since this can’t be resolved by any of the suggestions mentioned, can I trade this one in for a prorated rate new one? I use the functions on the other side of the swipe. @MarreFitbit
10-06-2022 06:51
10-06-2022 06:51
Hello,
i have the same issue with two fitbit versa 2 and yes i did aprox 15 reboot. Tried several original fitbit watch faces and also there current firmware.
as you see there are many maaany people with the same issue so please come up with a real solution. Or offer us a replacement!
10-06-2022 10:03
10-06-2022 10:03
Hey! Soooo my Versa 2 is doing the exact same thing!!!!! It's frozen, I have done alllllll the trouble shooting updates and more nothing! It was on charger took it off and now boom, it won't work and it's fully charged! Screen won't scroll, nothing. And I need my screen brightness adjusted. I always have it to normal well somehow on the charger it changed to Dim and I can barely see the time!!!! It's beyond frustrating!!!!
