06-22-2020
18:41
14:21
06-22-2020
18:41
14:21
My versa 2 suddenly won't turn on. My app says it has a charge but the screen won't turn on at all, even when I place it in the charger. It doesn't vibrate when being placed in the charger either. The HR light on the back isn't on.
I have already tried to restart it by holding down the left button for 10 seconds. It didn't work.
There is an update available but I don't update since the device isn't on and isn't being recognized by my phone.
What else can I do or is it just dead? Its only 5 months old.
06-24-2020 14:23 - edited 03-03-2024 09:34
Hello there @Zutley, welcome to the Community Forums. Thanks for the details provided in your post about your Versa 2's screen behavior. Thanks for taking the time to troubleshoot your watch prior to posting here, I'll be glad to help you.
Since the steps you've tried didn't work, I recommend doing a factory reset:
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Best Answer06-24-2020 16:34
06-24-2020 16:34
06-24-2020 16:49 - edited 03-03-2024 09:34
Hello @Zutley, thanks for getting back. I appreciate you've taken the time to follow the tips and recommendations I provided. Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
I'll be around if you have any questions present.
Best Answer06-24-2020 17:40
06-24-2020 17:40
Best Answer06-24-2020 18:21 - edited 03-03-2024 09:41
Hey @Zutley, you're very welcome. 😉
I'll be around if there's anything else I may do for you in the meantime. Have a nice day!
Best Answer06-24-2020 18:55
06-24-2020 18:55
What’s a back button?
Best Answer06-24-2020 19:02 - edited 03-03-2024 09:36
Hello there @Missys455, thanks for stopping by. The back button is the only button on the left side of your Versa. For an image and description of the functionality of the buttons, see the Versa manual page. 19, click here to check it out.
Let me know if you have any questions present.
19:17
03:05
06-24-2020
19:17
03:05
I have the fitbit versa and it won't turn on either. I've tried the recommendations on this post. Please let me know if there is a solution. Thank you!
Moderator Edit: Formatting
Best Answer06-25-2020 03:10 - edited 10-11-2023 18:16
Hello there @Andrea3019, welcome on board. I appreciate you've taken the time to follow the tips and recommendations I provided. I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
