I got the versa 2 and created a shortcut on set up. However, I wanted to change the shortcut. Also I dont meant the exercise shortcut. I mean when you press and hold down the button on the left side. I want to change that over to my alexa
From main clock face, scroll right (swipe left) to 'Settings' and tap that; then scroll down (swipe up) to 'Left Button' and tap that. It gives you several choices of what to make the left button do.
Quick question: what main clock page? I’ve been trying to find the settings area u said but I’m very confused
Best AnswerClock face (not page) = screen on your wrist that shows the time and, depending on which one you have chosen, probably other stats, maybe day and date.
I'm not sure this is what they meant. I have the same question. Which is about the small pulldown menu above the notifications. It shows 3 apps, music, wallet, and quick settings. How can I changed those 3 apps or disable that extra pulldown menu option?
@WolfChild13 wrote:I'm not sure this is what they meant. I have the same question. Which is about the small pulldown menu above the notifications. It shows 3 apps, music, wallet, and quick settings. How can I changed those 3 apps or disable that extra pulldown menu option?
I don't think you can disable that pulldown menu. As for changing the the app options there, I think if you change one of them to be the left button option, whatever you had for left button will take its place. But you cannot just choose any app to go there.
