10-02-2020
10:38
17:53
RicardoFitbit
10-02-2020
10:38
17:53
RicardoFitbit
Today my Versa 2 exercise details on the app for my workout shows time exercised as 9:34 to 10:15, yet it shows 28 minutes duration and 56 zone minutes. Both should show 41 minutes as that was the length of my workout. This is the first time I’ve seen this discrepancy. How can I fix it so future workouts register correctly?
10-02-2020
17:53
15:05
10-02-2020
17:53
15:05
Hi @SunsetRunner, welcome to the Community Forums!
Thanks for bringing this to our attention and for the details that were shared in your post. To better assist you with this, can you please let me know if you tracked the activity using your Versa 2 exercise shortcuts or with the SmartTrack auto-recognition feature? In other words, you saw such incorrect data directly on your device after concluding the activity or in the Fitbit app after syncing your Versa 2? Moreover, which activity were you performing? In the meantime I receive your answers, please restart your device and troubleshoot the app with the following steps:
Looking forward to your reply.
Best Answer@SunsetRunner -
I cannot speak to the duration issue. I'll let @RicardoFitbit do that. Unless, of course, you had pauses in the exercise lasting a total of 13 minutes.
Regarding the zone minutes-
For Active Zone Minutes, you receive one Active Zone Minute for each minute that your average heart rate for that minute is in the Fat Burn Zone. You receive two Active Zone Minutes for each minute your average heart rate is in either the Cardio or Peak zone.
So, if your exercise was somewhat strenuous, getting your heart rate into your Cardio zone for at least 15 minutes of the exercise, the 56 zone minutes would seem reasonable.
If you were below zone for any time, I would expect one more minute in Cardio for each two minutes below zone. Your exercise record should show minutes in each zone, with a recap of zone minutes below it.
<<edit>> reduced image size <</edit>>
I hope the above explains the zone data for you.
Welcome to the boards.
Best AnswerJust finished my workout today and the results on the app show correct data. Thanks so much for your help. Your suggestions did the trick!
