When the Versa 2 is connected to the charger and charger to the laptop (didn't try a plug yet), it shuts down while charging. The process of charging is still ongoing as, when turned back on, it's visibly charged.
Also, it turns on quite slowly - having to keep the button pressed for about 30 seconds. I haven't owned a fitbit until now, and don't know how it should behave when charging, since the button is not available due to the charger's clips. But, the watch doesn't wake up by removing it from the charger and pressing the button, as it should, I believe, normally do.
I had screen time-out set to 60s (due to the TRX app ending a work-out when the screen turned off - very very annoying) and always-on-display set to off, and thought this may be an issue. Switched the time-out back to 10s.
