12-06-2020
20:17
05:13
JuanJoFitbit
12-06-2020
20:17
05:13
JuanJoFitbit
Not tracking sleep, heart rate or SPO it is only tracking steps how to you correct that.
12-07-2020
05:13
10:06
12-07-2020
05:13
10:06
Hi @GCIuser123, welcome to our Fitbit Community. Since you mentioned that your Versa 2 stopped tracking your sleep, heart rate and SPO, I'd like you to try the troubleshooting steps that are listed in this help article in order to fix the heart rate tracking issue.
After this, check out this help page, which explains how your Fitbit device tracks your sleep data. Finally, visit this article, which explains how the SpO2 feature works.
After trying these steps, monitor your watch and see if the issues get fixed.
Keep me posted on the outcome.
08:29
10:05
12-09-2020
08:29
10:05
Hi @GCIuser123, thank you for trying the troubleshooting steps previously shared. I'd like you to try one more workaround, which has been helpful for this type of issues.
Please try a factory reset. To do so on your device, follow the steps below.
After this, set up your watch from scratch and see if your Versa tracks sleep, heart rate and SpO2 properly.
10:02
10:05
12-10-2020
10:02
10:05
Hi @GCIuser123, thank you for getting back and trying the recommended steps. Since the issue persists, let me go ahead and forward your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
I'll be around if any question arises.
