06-11-2023 14:23
06-11-2023 14:23
My Pixel 4 and my Versa 2 stopped displaying incoming Messages! I think All Notifications are Correct. I do get Gmail Messages though! Help my Wife thinks I am avoiding her FB Messenger messages!
06-11-2023 20:06
06-11-2023 20:06
Hi @SantaMike - if you are getting some messages on your watch it is more likely some change on your phone.
Firstly check that the message notifications appear on the status bar of the phone and if they do, in the the Fitbit App, click profile photo, device photo and Notifications, and if necessary App notifications to check the settings.
A reboot of the phone may resolve the issue, if everything is correct.
Note: depending on the timing of the message arrival, if you correctly set up a watch sleep schedule or turned it on manually it may seem that some notifications don't arrive (because sleep mode blocks them).
07-04-2023 04:46
07-04-2023 04:46
Thank You Guy- Old Guy with a Fitbit! Thank You, there was a Setting that had What's Up App instead of FB Messenger! Happy Wife now! Happy July 4th!
