03-20-2021 13:58
03-20-2021 13:58
Earlier this week my Versa 2 stopped syncing with my Pixel 4. I checked bluetooth on both devices. I removed the fitbit from the app, and then when I tried to add it in again, the app would find it, but couldn't connect. I tried removing and reinstalling the app, same results. Today I tried resetting the fitbit to factory defaults and now it won't boot up at all. I just get the fitbit logo for a few seconds then it fades away.
03-21-2021 23:10
03-21-2021 23:10
03-21-2021 06:21
03-21-2021 13:27
03-21-2021 13:27
My Versa 2 ran out of battery and now it won't sync so the time won't update! 😥
03-21-2021 23:10
03-21-2021 23:10
03-22-2021 06:30
03-22-2021 06:30
I tried logging in and out, have not tried the tip yet. However I still can't get the watch to connect to my phone. Using the fitbit app, I can find the watch, but can't connect to it.
03-22-2021 06:37
03-22-2021 06:37
@Myq13 It won't reconnect after a factory reset unless you did the setup again of the watch suggested earlier.
03-22-2021 06:46
03-22-2021 06:46
@Myq13 If its getting stuck in setup you need to
03-25-2021 12:46
03-25-2021 12:46
That didn't work either 😞
03-28-2021 10:40
03-28-2021 10:40
My fitbit went weird same day aswell, really nice lady at fitbit support talked me thru wat to do. Call 02033896416 and they'll talk u thru it all.
Tip * make sure got ur fitbit charger ready to plug in wen they tell u.
